disable flowmon
disable flowmon
Description
Disables Flow Monitor.
Syntax Description
Default
Disabled.
Usage Guidelines
Modification rules for groups, keys, and collectors remain active after Flow Monitor is disabled. A new group can be created and configured with its parameters, collector, template portions, and added keys. The group can also be enabled or disabled.
Enabling a group while Flow Monitor is disabled will program the hardware, but the flow collection for the group will be disabled.
The following command disables Flow Monitor:
# disable flowmon
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
